Rear Axle Bearings Corporate 10
Discussion in 'The Garage' started by engdray, Apr 6, 2003.
  1. engdray
    engdray Registered Member
    Jan 29, 2003
    5
    Mechanicsville, VA
    The problem started as just a little vibration...3 months later after the snow and cold has gone, I find out the rear wheel bearings are going bad. I pulled the wheels, diff cover and tried to take out the locking bolt on the center pin. To my surprise it came out relatively easy, except only part came out about, 6 threads the rest of the bolt is still through the pin. Could this have been a stress fracture? I used a little wrench with very little effort so I can't imagine breaking it. This is the first time I've ever tried to pull these axles. How can it be fixed? drilling and easyout would be near immpossible because of access and its only a 1/4" bolt. What can I do? /forums/images/graemlins/k5.gif
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Good thing you broke it and it didnt break while driving and the cross pin come out and eat your diff! If all the threads from the pin came out you can juts pull out the rest of the pin. Theres only a few threads on it the rest is a pin that goes throught the cross pin.
  3. engdray
    Jan 29, 2003
    5
    Mechanicsville, VA
    Unfortunately not all the threads came out. I tried for a good hour to see if that was the case but no luck, still tight.
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Please fill out your profile.
    I think there is a tool you can purchase from the Snap-on guy made for getting that pin out when it breaks.
  5. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    hey man same thing happend to me i just drilled the rest of the bolt out and the centerpin just slid right out. /forums/images/graemlins/thumb.gif
  6. engdray
    Jan 29, 2003
    5
    Mechanicsville, VA
    How does it work, will I need to cut the carrier?
  7. engdray
    Jan 29, 2003
    5
    Mechanicsville, VA
    This is looking like the first option. Thanks
  8. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    When this happened on my 10 bolt (before I trashed it) I drilled two small holes through the carrier where the bolt is (one where the end of the threads is and one where the end of the bolt should be) and used a pick to push the bolt out, then the cross shaft came right out. I bought a new bolt first so I could see where I should drill. I don't think it really effects the strength too much, plus I knew I was going to a 14 bolt within the year. Good Luck /forums/images/graemlins/smile.gif
