Rear Axle Bearings
Discussion in 'The Garage' started by 87gmcsuburban6_2, Apr 30, 2005.
  1. 87gmcsuburban6_2
    87gmcsuburban6_2 Registered Member
    Aug 25, 2003
    5
    How do you remove rear axle bearings in a 88 GMC suburban 2wd w/8.5 rear???
    Thanks in advanced
    Stan
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    remove the alxe shafts and use a slide hammer
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yep, pop the seals out and use a slide hammer. You need the correct size wnd, otherwise itll break, and could be harder to get out.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Have fun those tend to get stuck in there pretty hard. Try to have a propane torch in case you need the heat.
  5. 87gmcsuburban6_2
    Aug 25, 2003
    5
    thanks all
    after the first reply i went to autozone and rented the puller came home and popped it out (15 to 20 pulls) and installed the new bearing.the repair bearings are cool,it relocated the bearings on the axle and had a new seal already in it :grin:
    Thanks again everyone
    Stan
  6. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
