Rear Axle Exchange ??. - 91 half ton to 89 half ton?
Discussion in 'The Garage' started by woody9, Jan 28, 2003.
  1. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Will a 91 sub /forums/images/graemlins/burb.gif rear axle fit under an 89 1/2 ton /forums/images/graemlins/truck.gif p/u? (once i get into the newer years i never can remember) May have my old 10 bolt sold if it does!
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    It should fit! 89-91 all the burbans and blazers were still the same body style...should bolt right in. /forums/images/graemlins/thumb.gif
  3. woody9
    May 27, 2001
    602
    Howell, MI
    but, didn't the pickups change in 87? that's why i wasn't sure if the rear would swap.
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    yur right on that, they did change. id say measure em, and see if they will BOLT up. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yes, you're right about the pickups changing style.
    For some reason I'm thinking that the frames are wider on the newer body style (someone may want to confirm that) - so, if I'm right, the spring perches will need to be moved out and then it will bolt up.
    *just did a search in the ifs forum to satisfy my curiosity, and got the figure 47.25" spring perch center-to-center...as opposed to 42.5" like your burb*
  6. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    The 88 up 10B is wider than old style.I put 72 12B in 88SWB for while.Made it tight on inside of tires.14FF from 76 set width back out.Have to move spring pads,mabey shock mounts.Sub should work ok except pads. /forums/images/graemlins/thumb.gif
  7. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Do you know if both the 2wd and 4wd axles are the same width on the newer (88-98) trucks? Could you swap 2wd shafts into a 4wd 10 bolt like you could with the old 12 bolts?
