Rear Axle Gasket???
Discussion in 'The Garage' started by OffRoader93, Aug 28, 2003.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    I screwed up and got a gasket for a 10.5 ring gear 14b, and was wondering if anyone knows if Autozone or Napa would stock a gasket for a 9.5 14b??? Thanks.
  2. Living Large
    Living Large Registered Member
    Jun 22, 2002
    40
    Central CA.
    i just tried last week to get one from the GM dealer. They claimed that it was not available, and to just use silicone. The first gasket was also for a 14bff.
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Blue RTV will do just fine. I changed fluid a few weeks ago and used it and no leaks /forums/images/graemlins/thumb.gif.
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Just use "the right stuff" from part's house's everywhere. It does'nt leak.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Pretty much any RTV will work fine, I always use whatever I have on hand and have never had a leak. The key is to let the RTV skin up a bit before actually putting the cover on. </font>
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I 2nd that, although a 14 SF gasket IS available.
  7. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I also vote for the right stuff, but you better not ever wanna get in there again.
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i found mine worked perfectly without leting more than 15 seconds of drying. i put the bolts in and scraped off the excess, no leaks after 5 months.
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    9.5" useing 80/90 gear oils, require GMS (G.M.Silicone sealant) for sealing the bum-cover.
    (98-ish and up) 9.5" useing synthetic gear oils, will use a actual gasket. The synthetic gear oil will attack the silicone sealant, therfore requireing the gasket.
    9.5"ers are an odd bird, becarefull of that for when repairs/parts are needed.
