rear axle oil
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Psycho, Jan 11, 2003.
  1. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    anyone know how much gear oil the front and rear axles take.
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    About 3qt of something like this /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Eric
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Chiltons says:
    Front: 3.5 pts (1.75 qts)
    Rear: 4.2 pts (2.1 qts)
    Use a GL-5 80W-90 gear lube....unless the rear has a gov-lock. If that's the case, the rear will take some special limited slip lube (I think).
  4. 76k5Blazer
    76k5Blazer 1/2 ton status
    Sep 25, 2002
    176
    tracy ca
    GL 5 has the friction modifer already added to it /forums/images/graemlins/thumb.gif
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Unless you have a diff that NEEDS limited slip additive, use GL4. GL5 is the same stuff except it has sulfer added to it (that's what the additive is) which will combine with water to make sulfiric acid. So, if your diffs will see any water, and you don't need the additive, GL4 is safer.
