Rear axle option code?
Discussion in '1983-2005 S-Series models' started by kennyw, Mar 3, 2003.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Anyone know where to find the rear axle gear ratio on the option code label? I have a 2wd 1986 Chevy S10 w/ 2.8L & 5 spd OD tranny. Rear axle tag says 4.10 ratio but speedo is way off. I think someone swapped rear axles at one point and I want to put in the correct ratio again that came stock for better gas mileage (this truck will be my commuter).
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I believe if i remember right, all axles codes start with a "G" /forums/images/graemlins/thumb.gif
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have a 87 ext cab 2.8L with 7004r and mine has 3.42's in it.
  4. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    I have an 86 S-10 2.8L 4x4 700R4 and mine has 3.42s also.
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    3.73 is very common with 2.8L/5-spd combo.
