Rear axle quiz
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Andreas, Jun 23, 2000.
  1. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    Ok, all you drive line experts. What the h*ll is this? Eaton? If it´s an Eaton rear, is the bolt circle exactly the same as other "newer" 3/4 ton - 1 ton axles (such as Dana 60 & GM 14 bolt). Is it worth spending my $$ on these axles. I get this rear along with a Dana 44 front, both with 4.56 gears for a good price. Actually, I get both axles for half the price of what a single Dana 60 rear would cost me. They´re from a Surburban 70.
    Andreas
    406cui of pure sh*t[​IMG]
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Yes, that is the old corporate axle, precursor to the current 14 bolt full floater. I believe that they were made by Eaton. They are a good strong axle, but gears and lockers are no longer available new. You should be able to find bearings if needed. Some people have reported that they find tons of them in junkyards, which would be the only source for gears. Some were fitted with Detroit Lockers, and those can be found in salvage yards also.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yep that's and old school rear end My father-in-law has one in the back of his 3/4ton 724x4pick-up.
    I would not get it just cuz of parts availability, slim pickins..............
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  4. Andreas
    188
    Sweden
    Another thing. It has the number 3934635 and DG2 922 stamped into it. What about the shock mounts? They look way narrower than my 12 bolt currently sitting under my Blazer.
    Andreas
  5. Burt4x4
    6,854
    Duno what the # mean???
    But the shock mounts, I would relocate them if your gonna go with this rear! Cuz the further away from the spring pearch the less effective they are for doing thier job!
    Good Luck
  6. Andreas
    188
    Sweden
    Anybody got some other info on this axle, such as splinecount, ring gear diametre etc. etc. ??
    Andreas
