Rear axle seal?
Discussion in 'The Garage' started by epurdy2005, Sep 13, 2006.
  1. epurdy2005
    epurdy2005 Registered Member
    Jun 7, 2006
    34
    Marion,IN
    I noticed something leaking down my tires about a month ago. I took my tire and and drum off and inside was full of grease. I'm guessing this is the seal for the axle thats gone bad. How hard is it to replace it? ANy special tools? DO you have to take the brakes off?
    Evan
  2. ct85k10
    ct85k10 1/2 ton status
    Oct 25, 2005
    121
    Charlotte, NC
    its realy easy to do im asuming you have 10bt/d44 all you have to do is pull the axel shafts pry the seals out tap the new ones in and reinstall the shafts
  3. dyeager535
    26,979
    Yes, you need to take the brakes off, they are probably contaminated with oil, and even a little bit ruins the pads, so you should replace them.
