Rear axle seals replacement advice?: open 10
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Udy, Jul 23, 2000.
  1. Udy
    Udy Registered Member
    Apr 2, 2000
    79
    fairport NY
    I'm preparing to replace the axle seals on my '91. Anyone have any hints/directions for removing the c-clip(s?) or any other part of the job? I bought a seal remover. It apears easy according to the Haynes manual I have. Thanks for any info.
  2. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    Dont snap the small bolt in the carrier its a pain to get out if you do.
    J.D.
    88 Gmc Jimmy
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    After you remove the carier pin push in on the axel shafts, this will release the c-clips and you can pull the axels out...thats about it
    Good luck
    Brent
  4. Udy
    Apr 2, 2000
    79
    fairport NY
    Just finished! Actually, the hardest part was the rear brakes! Thanks
  5. 79Guy
    79Guy 1/2 ton status
    Jul 8, 2000
    178
    Southeastern VA
    Must have been quite some project. Looks like you were a "newbie" when you started, and a "journeyman" when you were done! Must have learned alot!
    Owner of Two Great 4WD
    - '79 Blazer
    - '99 ML320
  6. Udy
    Apr 2, 2000
    79
    fairport NY
    Interesting point. Does the web page update status after a certain number of posts?
  7. MudRebel350
    May 20, 2000
    324
    N.J.
    yes it does update your status after a certain number of posts.
    J.D.
    88 Gmc Jimmy
