Rear axle shimy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by caleb22, Jan 7, 2006.
  1. caleb22
    caleb22 1/2 ton status
    Apr 15, 2005
    193
    SC
    We added a 4" ord shackle flip to my 89 Blazer, TC SX8000 shocks and TC front springs. Below 15 mph no vibration. 15mph to 25mph we have vibration in the rear. Do we need to add shims to the rear springs for proper shaft pinion angle?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    WHen you do a flip it point the pinion right at the tcase. this is great for a cv shaft, not good for a regular shaft. get a angle finder (like 10 bucks and home depot) the pinion angle and tcase angle shoul d be with 2-3 degrees of each other. youll most likely have to shim the pinion down a lil
  3. caleb22
    Apr 15, 2005
    193
    SC
    Would a 1" zero-rate from ORD in the rear help?
  4. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    zero rates would bring the axle back, but it would also give you more lift that would be bad in your situation... yesterday i did a free trick to gain some wheelbase, i just drilled out my spring perches and spring plates so the center pin would be offset moving your axle back, free and it would help a bit but i wouldnt count on it fixing your problem though and it might pull your slip yoke out, i think what dleroy was explaining to me while he was doing it to his burban was to match the angles the u-joints are are so tip down your pinion to match the angle your top u-joint is at... dont quote me on that though, ill let somebody else chime in and correct me here if im wrong
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    what do you mean, he said nothing about wheelbase... a zero rate doesnt have to move the axle. To fix the problem try lowering you tcase . take the spacers from above the frame rail and put hem below, this will point th back of the tcase down (equivilent to shimming down the front of the pinion) if this works get some heavy wall 1"x1 1/2" or 2" wide steel tube and use that as a spacer.
  6. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    :doah: :doah: I totally forgot about making the angles of the ds the same. Bill, I have the tool(anlge finder) to check it.
    Thanks for reminding me:D
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    oh so you were the "i know what im doing helper" i guess we have you to blame it all on then:D:p:
  8. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    yea, it was me. I'll take the blame. I'll also fix the problem:D
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    at least your willing to do that...
