Rear Axle Spacers
Discussion in 'The Garage' started by bigbluesuburban, Feb 28, 2006.
  1. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    I just bought new 16x8 MT Wheels for my sub. The rear track width is a little narrower than the front... or at least it appears that way. Since this is my daily driver I want it to look great. So I would like to have the rear wheels out even with the wheelwell. So before I go do all the measuring, does anyone know how much spacer I am going to need, and is there a manufacturer who might have said spacer in stock and ready to ship?
    Thanks for the info.
    Oh, and I need them for the 3/4ton 8 lug truck.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Not sure where you can get them any more. Tony P on here used to make them, but i havent seen him post in a long time. 1.5" on each side will make it equal to the front.
  3. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
  4. dirty77
    dirty77 Registered Member
    Feb 27, 2006
    24
    missouri
    When your out wheeling will the spacers become a weak point?
  5. bigbluesuburban
    Feb 8, 2006
    1,362
    hope not
  6. chickenass
    chickenass Registered Member
    Mar 12, 2003
    19
    Humboldt, CA
    You could just swap a van 14 bolt in. That will give you an extra 1.25" per side. It evened mine out close enough that you can't tell a difference. I had to relocate the spring perches and shock mounts to fit it under my Blazer. Not sure if you would on a 3/4ton.
  7. 13lazer
    Dec 30, 2004
    115
    San Pedro, CA
    possibly, clean threads, proper torque sequence, and inspect often. it depends on how much you like your rims and how cheap they are. i recently got a few sets of $1200 rims and tires for nothing so its worth my time to get spacers
  8. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I just got a set from caleb22, can't remember where he got the from though.
  9. caleb22
    caleb22 1/2 ton status
    Apr 15, 2005
    193
    SC
  10. bigbluesuburban
    Feb 8, 2006
    1,362
    Lets see... $100 spacers, 16 lug nuts, and Nelson Tires does it for free while rotating my tires... OR... New rear axle $X00.00, welding and fab work at local shop $X00.00, Perhaps Brakes and seals and whatever else to get up to acceptable quality$X00.00, Gear Swap $X00.00, and Lots of down time. TOTAL $XX00.00 +/-
    Hey I appreciate that suggestion. But I think the spacers are the way to go.
  11. chickenass
    Mar 12, 2003
    19
    Humboldt, CA
    My 14 bolt cost me $150 and I had the welding done for free. If you think swapping a rear axle is going to cost you over $1000 you need find a better junk yard and learn to do some of the work yourself. It just seems like a lot safer of an option to me.
  12. bigbluesuburban
    Feb 8, 2006
    1,362
    Well I guess you are THE MAN!!!!!!
  13. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Many years ago I used the Performance Wheel 1.5" spacers on the rear of my Blazer (6-lug at the time). I had bought them used off of Steve (ColoradoK5) who had used them on the UAV previously.
    I never had any problems with them including doing quite a bit of light to moderate wheelin' with 35" tires.....including breaking the front 10-bolt twice.
    Here is a old write-up on them:
    http://www.off-road.com/chevy/reviews/spacers/
    And here is the webpage:
    http://www.performancewheel.com/Spacers.cfm?category=6#pricing
  14. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    I have perf wheel spacers also, 1.5", never had a single problem. The nuts stay tight. I have probably checked their torque 30-40 times since I installed them 3 years ago... and they have never, ever turned at all... the torque wrench just goes "click click!" at me. I don't see any reason, safety or otherwise, not to run spacers to even out the track width.
    j
  15. bigbluesuburban
    Feb 8, 2006
    1,362
    I agree, I agree, I agree.
    I would also wonder if the van rear axle is as easy to get parts for? Broken axle shaft? Is it as common as the truck? Are the brakes the same? I guess I see the van axle as the long way around.
  16. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    As far as I know, most all of the parts interchange with no problems. Shouldn't be any harder to get parts for than any other ff14b (read: not hard at all!).
    As far as being the "long way around" it all depends if you can weld or not. If you can, its a simple/easy/cheap swap, if you can't (or dont know someone who will weld perches etc for you) it ain't.
    j
  17. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    AFAIK, the only difference is the van 14b shafts are longer. I know you will worry, but how often have you broken 14 b shafts of any kind? Or seen others break them? Not often.
