rear axle width
Discussion in 'The Garage' started by 85Jimmy, Jan 13, 2004.
  1. 85Jimmy
    85Jimmy Registered Member
    Oct 30, 2001
    97
    Great Falls, Montana
    Hello people- I have a ? about swapping rear axles from a 10bolt to a 12bolt my 10 bolt is currently 3" narrower than my front is there a 12bolt that is the same width as a 10 bolt front axle? or will i need spacers to get the same width? thanks for the help k5rs, Chris 1985gmc jimmy /forums/images/graemlins/k5.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no because in 1970 they widened to the width that they were after 69
    64-69 12 bolt are actually 1.5" narrower
    and you wont be able to widen an SF axle cuz you wont be able to install C clips again if you move axles outwards any, maybe you can order longer shafts for one though, and lengthen the tubes maybe
    good luck
  3. 85Jimmy
    Oct 30, 2001
    97
    thanx, /forums/images/graemlins/k5.gif i heard the 2wd models are wider is this true?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope.
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    you can get a 12 bolt out of a 1/2 ton van and it is about 4'' (?) wider than the truck 12 bolt, but you will have to move the spring perches.
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    A 70's 12B is the same width as an 80's 10B. A buddy just blew out his 10B in his 87' blazer and swapped in a 12B, they are the same.
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    The key isn't the year, but the application. That's like saying all '70's 14B are the width wms to wms.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oh and the 12's and 10's with the 2.75 wide rear shoes are another 1.5" wider BTW, the shafts and tubes are same length no matter the brakes size
    10 bolts and 12 bolts are same width and yes the key IS the year when it comes to the GM truck 12 bolts, '70 and up being 1.5" wider than 64-69, 2.75 wide shoes didnt happen until sometime after 72, and finned drms didnt happen until 71 when front disc brakes were put on trucks and when 2wd pattern changed to 5 lug
  9. 85Jimmy
    Oct 30, 2001
    97
    thanks for all of your help k5rs , Chris
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    let us know what you decide to do, if anything /forums/images/graemlins/laugh.gif
