rear axle
Discussion in 'The Garage' started by john deere, Mar 4, 2004.
  1. john deere
    john deere Registered Member
    Mar 4, 2004
    5
    my 87 k5 is makeing a thumping noise from the rear axle and grabs litely. worse in turns when giving it gas. but will still do it when coasting or going straight. when it gets real bad i can stop and back up and it will quit for a little while. it has a gov-loc, could it be trying to engage
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sounds like the gov loc is about to explode /forums/images/graemlins/yikes.gif
  3. john deere
    Mar 4, 2004
    5
    thats what ive been thinking all day. whats a good replacement for the gov-lok on a daily driver
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    If it has a gov-lock, which you said it does, then that probably means that the gov-lock is about to crap out on you. Gov-locks are notorious for doing that. Common symptons would be noises from the rearend, and the gov-lock acting up like you are describing. Looks like it is time for a new rearend. You can just buy another 10B, or if your looking for something more heavy duty, or if you want to one day run bigger tires, go with a 14ff. They are a dime a dozen.
    -Harrison
  5. 87BrnRsd
    Apr 21, 2003
    2,457
    Sorry, but there is some bad news. You can only put another gov-lock in a differential that a gov-lock came out of. Get a new gov-lock free axle, and put in a detroit. Best locker on the market.
    -Harrison
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if you want to replace it then you need a different carrier. if it was me, i would put a open carrier in it, then put a lockright locker in it.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If I was gonna set up gears I'd just put in a detroit.
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    where are you at, i have an open 2.73 carrier ill almost give you /forums/images/graemlins/deal.gif
  9. john deere
    Mar 4, 2004
    5
    lexington kentucky
  10. 87BrnRsd
    Apr 21, 2003
    2,457
    What do you plan on doing with your truck?
    -Harrison
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]14 bolt FF. You'll need a conversion U-Joint, and the 8 to 6 lug adaptors.
