Rear Axles
Discussion in 'The Garage' started by IronMan, Nov 16, 2002.
  1. IronMan
    IronMan 1/2 ton status
    Nov 16, 2002
    223
    Bay Area, CA
    A little help...
    I was wondering if someone could give me some info on what axles are used on the new GM HD pickups. 14 bolts? Dana 70 or 80's? I would like to use a Dana axle for the rear of my 83' 1 ton. I have an ARB for the front and would like to match up the rear. Can you use the disks in the rear for the older pickups? Has this been done? Any help would be appreciated.
    83' K30 4x4 Reg Cab LB
    500ci Caddy/NV4500/ORD Doubler/Dana 60 Front Rear?
    /forums/images/graemlins/truck.gif
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    my 2002 2500HD has a 14FF out back
  3. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    A bit of info the dealer shared with me. The 2500's are the 3/4 ton, as we all know. 14 bolt rear. The 3500's are the 1 ton with a 14 bolt. All the 2002's 1 ton's are duallys. A 2500HD is the same as a 1 ton, except it is a single wheel rear. The dealer didn't really specify anything other than they are the "same." If this started with the 2002 models I'm not sure.
  4. sapper
    Jul 11, 2001
    3,052
    NoVa
    that sounds right, but all of the 2500s iv seen have the 14SF in them. I guess thats why my HD with the FF. Dont know if there is a towing wieght diff or not.
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The 2500 (light-duty series) has the FF rear when its optioned with the 6.0L and 5-spd... otherwise they're all semi-floater.
    I would hope all the HD's use a full-floater /forums/images/graemlins/blush.gif
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    2500HD trucks with the 6.0 l engine get the 10.5" 14 bolt ff. 2500HD trucks with the 8100 or Dmax, and all 3500 trucks get the 11.5" 14 bolt ff. No more Dana rears in GM light trucks.
