rear bearings
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Tonka, Aug 20, 2002.
  1. Tonka
    Tonka Registered Member
    Jan 28, 2001
    30
    Fort Worth TX
    Thanks to all who helped me with my ball joint issues. Now I'm getting ready to tackle the rear wheel bearings. Another task I have never tried. Does anyone have any hints or suggestions. I understand it takes a slide hammer or some kind of bearing puller to get them out. Is this another autozone rental thing or something I have to buy? Anything else to look out for or prepare for?
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    What axle do you have? Advice depends on whether it's full floating type or semi-floating. Mine's a dana60 which is full floating and replacing the wheel bearings is straight forward.
  3. Tonka
    Jan 28, 2001
    30
    Fort Worth TX
    Mine is not a full floater. I believe it is a corp. 12 bolt.
  4. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    12 bolts are simple. pull the spider gears then the c-clips, and remove the axle. Then you borrow the bearing puller from auto zone, remove old and tap in the new ones.
    peice of cake
    have fun
  5. Rasberry
    Mar 30, 2001
    205
    Orlando, Fl
    it goes without saying, but just in case, replace the seals at the same time.
