rear body support
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KENNY, Mar 31, 2002.
  1. KENNY
    KENNY 1/2 ton status
    Dec 7, 2000
    292
    nyc
    my 84 is rusted in the usual places no more so that the rear cab support on both sides. how do you fix this.
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    When I did my bodylift I simply made 2 square pieces of metal and drilled a hole for the bodymount bolt to pass through. Both sides had the metal square that lays on the rubber mount rusted so bad it crumbled upp in my hand when I removed them. If what your talking about is in the bed itself you can probably get away with the same teqnic, but cutting the rusted bed portion out and welding new metal inn is your best option.
