Rear brake distribution block?
Discussion in 'The Garage' started by txbartman, Jan 15, 2003.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    my 14bFF didn't come with a rear brake distribution block (the one that bolts to the top of the diff housing) and the brake lines were shot. I can get the hard lines at the local parts store, but where do I get a distribution block? The dealer doesn't even list a part number!
  2. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    Isn't the distribution blok on the rubber brake line? That how is was on mine...
  3. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    Duh! You are absolutely correct! Nice to learn something from a newbie every once in a while! Would make sense why my axle didn't have it!
  4. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    I am tring to put my 8" lift on now and I am tring to find the dis. block also. I have the longer brake line for the back already.
    Any suggestions?
    Mike B /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  5. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    When I got my extended brake lines a LONG time ago, the block was already on the flexible line.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thats how mine was also. On the line itself.
  7. Grim-Reaper
    7,385
    Atlanta
    Should be on the end of the line. I have a 28 inch long DOT rubber line /forums/images/graemlins/smile.gif
    There are lines out with the correct fittings that you could hook them together. Some where in a brake post I listed the part number. I use a thin bungee to keep it out of trouble. It would be laying on the top of the pumpkin if I didn't.
  8. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    If worse comes to worse you can always go through the brass fittings bin at the hardware store and create three way adapter. But It does come with the new line. /forums/images/graemlins/grin.gif
