Rear Brake Hard Lines
Discussion in 'The Garage' started by 89Blazer4wd, Jun 11, 2006.
  1. 89Blazer4wd
    89Blazer4wd Registered Member
    Dec 11, 2005
    16
    Woodbridge, Va.
    Where can I get these? I looked on Advanced Auto's site and they only have the rear rubber line that has the distribution block attached to it. I need the hard lines that go from there out to each wheel cylinder. Is this a dealer online item or can they be found somewhere locally??
    Thanks,
    Patrick
  2. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Unfortunately, either the dealer or LMC has them.
  3. 89Blazer4wd
    Dec 11, 2005
    16
    Woodbridge, Va.
    I checked out this site and they either have the original equipment pre-bent lines for 73-82 or you have to buy an entire vehicle hard-line kit for 73-91 for $219. are those the only two options or am i missing something?
  4. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Another option is make your own, a bender, tubing cutter and flaring tool is needed, then you can just get brake lines at any auto parts store.
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yep. both my 12 bolt and the 14bff were 3/16" tubing. if at all possible, id measure what kinda lengths you are needing and try to buy a pre-cut & flared piece. just makes things cheaper and easier.
  6. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    When doing that make sure the threads are the same. Some are metric.
  7. dyeager535
    26,980
    You can buy hand-bendable lines for the rear, although you may not find some that work out to the exact right length, just add some creative bends. :)
    They already have fittings on them, so it's pretty easy to do.
  8. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    What he said.
    Measure the actual length along the existing line, then buy the parts store hard linethat is equal to or longer than thhe existing line. Then, just hand bend it, Like dyegear said, if you have too much hard line, some creative bends to take up the slack will take care of it.
  9. gtchief
    gtchief Registered Member
    Apr 15, 2004
    33
    I just did my front and rear hard lines friday. I bought them at advance auto and got all 4 for $17. I think I got a 30, 2 40s, and a 50. I cut the two rears and the right front, borrowed a double flare tool and all seems well. I just bled everything today and no leaks.
