rear brake hardline broken;no fluid leakage?!
Discussion in 'The Garage' started by jones, Aug 21, 2005.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    just like it says,guys.doesn't leak at all,at anytime.it should be pissin'out the fluid when i hit the brakes,right?what's goin' on?please help!thanks
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I'd guess the resevoir for the rear brakes is empty...so no fluid to leak out.
    Rene
  3. jones
    May 17, 2004
    379
    IONIA,MI USA
    Wrong,sorry!resovoir Is Full,no Lines Pinched Off.what's The Chances Off The Stock Proportioning Valve Isn't Working Properly And Only Getting Fluid To The Front?how Would I Check It?is It Easy To Fix?anyone Else...please Help!
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I thought there was a check valve of sorts that prevented the fluid from draining out of the system for that very reason. I thought it was located in the proportioning valve. Am I way off base?
    Ira
  5. masterbeavis
    masterbeavis Registered Member
    Aug 10, 2004
    20
    El Dorado ca, East of Sacramento
    I seen this happen on a '98 chebby 3/4 ton P/U. A wheel cylinder went out on it, replaced it, and could not get fluid to the rear. The mechanic had to take it to the dealer to get it fixed. Not shure what fixed it, or what was wrong, never asked.
