Rear brake line
Discussion in 'The Garage' started by Muddytazz, Jul 7, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I tried a search of a bunch of different combinations and came up empty(guess i don't know the magic wording). Anyways, on the 14FF, i'm looking for a extended brake line that runs from the frame rail to the distribution block(including the dist block, since they are permanently afixed to each other). What have you all used?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    OrmeBros.com has the block for -3AN. I got it, some -3 hose, two hose ends, and the frame end I.V. flare to -3 adapter from them and made my own.
    Also got the bits to do the fronts from them, but have yet to get to it.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    we just did a 10b-14b converion on an 84...used i think a skyjacker rear hose... could be wrong, ill ask tonight and repost, for now see if skyjacker has one...
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    you could take the hose you have now to napa or any other parts store and match up the hose to a longer hose with the same fittings.or get the ones form superlift or call 4 wheel parts and see what they got.AZ kicken offroad can make a custom one.they are making hoses for the disk brake kits and im sure they can make a extended rear hose for ya also.
