rear brake lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gaine7, Dec 2, 2001.
  1. gaine7
    gaine7 Registered Member
    Apr 5, 2001
    23
    Clemson, SC
    Need help getting the rear brake line fittings off my 79 so I can get the new extended Pro Comp line on. Any help would be appreciated....what a PITA.
    Clemson K5 1979
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    mine bolted right in no problems
  3. gaine7
    Apr 5, 2001
    23
    Clemson, SC
    I can't break the block free from the lines nor the top fitting off the bracket above the gas tank. I have used wd40 on all of them just wainting for advice now.
    Clemson K5 1979
  4. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    I usually end up using adjustable pliers on them as they are so soft and tend to strip with a wrench. You might try penetrating oil to as it would work better than WD40. Good luck!
  5. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    HACKSAW!!!!!!!!!!!!!!!!!!
    when all else fails..............HIDE!!!!!!!!!!!!!!!!![​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/albun32>http://coloradok5.com/gallery/albun32</a>
