rear brake lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gaine7, Dec 4, 2001.
  1. gaine7
    gaine7 Registered Member
    Apr 5, 2001
    23
    Clemson, SC
    I am at my wits end with these rear brake lines, I can't break them free of the block so i can install the steel braided extended one. Are there new brakes lines as well that I can buy? should I just rip out the old lines from drum to drum and install new lines?
    Jim
    Clemson K5 1979
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    You can get the brake lines that go to the block from the drum for around $3 each from Napa or Autozone. I would suggest just replacing them.
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  3. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    Dealt with the same thing. I ended up replacing all the lines as well as the rear wheel cylinders. It was much easier to rip the old rusted to garbage lines off, than to fight it.
    "Why is there a <font color=red>watermelon</font color=red> here?"
