Rear Brake Noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Frank, Jul 6, 2003.
  1. Frank
    Frank Registered Member
    Oct 2, 2001
    16
    I replaced the Brake Shoes, Wheel Cylinder, and had the Brake Drums re-surfaced on my 87 Chev Blazer.
    My problem, is the right rear bakes makes a scraping noise when I apply the brakes.
    The adjustment on the brakes shoes are within specs.
    I'm puzzled. What could cause that scraping noise??
    I Would appreciate any advice, thanks!
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    did you lube the backing plates with some dielectric grease when you put it all together? theres maybe 3 or 4 tabs for each brake shoe that ride on a little spot on the backing plate...its a possibility..
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Why would you use dielectric grease for a mechanical "connection"? Did you mean Lithium grease? /forums/images/graemlins/thinking.gif
  4. Confedneck
    Nov 1, 2002
    5,236
    uhh negative, dielectric grease is what it is..its thick enough to work perfectly, its what we use at work.. use it on all my brakes.. also use it to lube front caliper slides..dielectric grease/brake parts grease is what its called and its the same as regular dielectric grease...works great
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    your all wrong, its never seize. /forums/images/graemlins/rotfl.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. Confedneck
    Nov 1, 2002
    5,236
    87, ive heard that from some of the northern transplants i work with... never used it, would work though...
