rear brake problem on 87 sub.
Discussion in 'The Garage' started by pinantanman, Jan 5, 2006.
  1. pinantanman
    pinantanman Newbie
    Nov 20, 2005
    4
    pinantan lake B.C.Canada
    I have a 87 3/4 t. sub , before and since I raised it a lot of the time I would only have front brakes, there is an arm atached to the rear axle that needs to be in the rite poss. in order to work and I dont know where, any ideaswould be apreciated.
  2. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    either bypass it or put the arm where it would be if it was stock height with a load causing it to squat. it's a GM load proportioning valve.
  3. pinantanman
    pinantanman Newbie
    Nov 20, 2005
    4
    Thanks , I was not shure if it could be bypassed without causing problems.
