Rear Brake question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigTex, Apr 5, 2002.
  1. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Hey guys and gals. I'm currently rebuilding my 14FF and as I was redoing the brakes, I noticed the guy who had it before me put both secondary shoes on one side and the primary shoes on the other side. Just to confirm, the "longer" primary shoes go on the front (forward) and the "shorter" secondary shoes go on the rear of the backing plates, right?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Short shoe goes forward and long shoe reward.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    4x4High has it right.
  4. BigTex
    Dec 27, 2000
    974
    South Texas
    Ok, so if I'm understanding you correctly, the short shoe faces the front and the longer shoe faces the rear? I guess I had it mixed up if that's the case...
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Yes, now you have it correct. The reason for this is that the front shoe applies first which then throws the weight to the rear shoe. Since the weight is now on the rear shoe you want the larger shoe in the position.
