rear brakes lock up...help!
Discussion in 'The Garage' started by PsychoticDeadGuy, Aug 9, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I just finished my 14bff swap, or so i thought. i took it down the street and it drove great...until i pressed the brakes...the passenger side locked up on the 14bff. is it just because of the larger brakes or what? i am running 33s on it front & rear. whats the deal? whay doest the driverside lock up? should i replace the drums and shoes? or what? thanks
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    could be a leaky wheel seal or cylinder. The pads get saturated with oil/fluid and it creates an instant grab with the slightest touch of the brake. Or if its got a gov loc you may have a problem with that.
    Check for wet shoes. If so, fix leak and replace with new shoes.
  3. PsychoticDeadGuy
    Jan 8, 2005
    753
    the side that did have the seal leek doesnt lock up...its the clean side that does...i got the dirty side almost near clean. i dont have the money to spend on those 1 ton brakes right now...it is an open diff i believe...
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I second the oil soaked pads.
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    If its an open diff then new shoes would prob fix it.
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, i will do the shoes, anyone know about how much they cost? with the hardware kit? i need to have this running in 2 weeks...
  7. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Looks like around $25 to $35 for the riveted Wearevers. Make sure to take the old ones with you for the core and to make sure you get the right ones.
    I think $12 for the kit.
  8. 4wheelattitude
    4wheelattitude 1/2 ton status
    Aug 5, 2005
    145
    central Illinois
    Did the brakes release at all?
    Did the brakes release?
  9. PsychoticDeadGuy
    Jan 8, 2005
    753
    yes, they do release after i let off. then it will drive fine until i try to stop again. why?
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    some trucks just do this, you have to remember that rears of empty trucks are light, and the big brakes in the FF's make it easy for this to happen, ive seen it happen alot,
    from my own personal experience, leaking brake fluid on shoes will cause lockup.. and very, very easily
    or they could be metal to metal, which ive seen happen also
    or the truck has great brakes and is just too light in the rear, or the prop combo valve may be faulty and letting too much fluid to the rear
    thats always possible too,
    stuff is old, has wear
  11. PsychoticDeadGuy
    Jan 8, 2005
    753
    it locks up with almost no brakeing though...i guess i will just change the pads and see what happens
  12. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    I have had a few things cause the lockup. soaked pads of course, air in the t valve let one side work and not the other and a brake hose collapsed on the inside causing it to work like a check valve.
  13. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    back off on the adjuster.
