Rear brakes question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pornorob, Mar 2, 2005.
  1. pornorob
    pornorob 1/2 ton status
    Jul 12, 2001
    215
    ;jkl;
    when I step on the brakes the pedal goes nearly to the floor and once the brakes start to engage they just lock up. I am running a dana 60 in the rear. I was wondering if the brakes just need to be bled or is it something more serious(or costly?). thanx guys
  2. pornorob
    Jul 12, 2001
    215
    ;jkl;
    no idea huh ??? wow I thought this would be a pretty basic question.
  3. Nicks 72
    Nicks 72 Registered Member
    Feb 11, 2005
    64
    Concord California
    When you say it has a Dana 60 in the rear,was that a transplant or original. Is this a new problem to a truck that was braking good before or had you just installed different parts(different axles,master cylinder,porportioning valve etc) and then after this you ended up with this problem. Does it have vacuum or hydrostat for PBrakes. Need more specifics.
    Nick
  4. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Yup, need a little more background
  5. pornorob
    Jul 12, 2001
    215
    ;jkl;
    bled the brakes and that fixed the problem . The fluid was almost black. can anyone tell what that means? is it just old or is it contaminated?
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Brake fluid goes bad by absorbing moisture from the air, lowering its boiling point. The dark color can be attributed to rubber components breaking down in the brake system - master cylinder, wheel cylinders, brake lines, etc. Some people (race vehicles especially) recommend changing brake fluid atleast once a year. You should be fine if the bleed job fixed it up.
