Rear brakes?
Discussion in 'The Garage' started by MagnuM4WD, Sep 22, 2006.
  1. MagnuM4WD
    MagnuM4WD 1/2 ton status
    Jul 26, 2006
    138
    Bucureşti - România
    Hi! What type of drums, have GM 14bsf 9.5" ring gear: 11", 11-5/32", or 13"?
  2. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    Pretty sure you got 11 ' drums on that 14bsf.
  3. Tabb
    May 2, 2006
    3,566
    21
    Heart of Dixie
    11" drums not 11ft.
  4. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    The shoes, have aprox. 70mm width! Can be 11-5/32"? Is from V2500 Suburban.
  5. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Well, I'm pretty sure that the 13" only come on 14BFF's, but it's a tossup as to what the other axles come with ... I swear I had 11 5/32"s on a 12bolt.
    Anyway, you know what the LMC catalog says:
    11" brakes have 2" wide shoes
    11 5/32" brakes have 2-3/4" shoes
    13" brakes have 2-1/2" wide shoes
    70mm is right about 2.75", so yeah, I'd say you have the 11 5/32"s.
    -- A
  6. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    That's the way, I believe to, but, onest, I'm not shore!
  7. dremu
    Feb 27, 2000
    15,967
    459
    Well, the other possibility is the 11" brakes, which would be a 51mm (okay, 50.8mm) wide shoe. Presuming you can measure 51mm from 70mm, I would say it's safe to assume you have the 11 5/32"s.
    -- A
  8. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    Where you measure the drum diameter; inside, or outside?
  9. dremu
    Feb 27, 2000
    15,967
    459
    Inside. It might even be cast into the drum, though that's a nominal value -- the 13"s I just checked are "MAX DIA 13.09", for instance.
    -- A
  10. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    Thanks!!!:waytogo: :burb:
  11. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    OK! After I find all this informations, I go under the truck and I make some measurements... and... :eek1: surprise!!! The inside diameter of the drum, is 330mm!!! That mean 13"!
    I looking also, to the steering controls and I find different tie rods, LH - RH! :confused: The RH is short (aprox. 150mm) and the LH is long (aprox. 1350mm), connected with a short adjusting tube. In the LMC Catalog, they say, this steering control, is use, only on the trucks with 13" rear brakes and 4.10 end ratio!
    Can be 13" brakes on GM 14bsf 9.5" ring? It is in this way, from factory (stock), or is a kind of special order?
  12. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    ... :confused: ...
  13. dyeager535
    26,981
    I don't have my manual handy or I'd look it up for you.
    Where did this truck originally come from? (I mean where was the original destination) Stateside there were no "special orders", only options that you could specify. The manual will show everything available that year. Of course, there were variations in vehicles made for other countries though, that we may not have had as possibilities.
    Just went and checked cskauto.com (stateside parts store chain) and sure enough, 13" drums with 9.5" ring gear is listed. Even have a picture.
    Not sure if this link will work or not:
    http://www.partsamerica.com/ProductDetail.aspx?mfrcode=RAY&mfrpartnumber=8022DGS&parttype=222&ptset=A
  14. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    It was made in 1991, in US - Flint Factory and bring in to Romania, in 1993, by Christian Aid Ministries.
  15. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    Fwiw..
    I had 13" x 2.5" brakes in my 74 k20's 14 bolt SF--it came from an '86 K20 with a 8600 GVW ..my 82 K20 has an identical one to it also!..
    I think both were 4.10 ratio--I know the one in my 74 was for sure,I've yet to pull the cover on the 82--I fear I'll find a Gov-loc in there!..:eek1:
    Mostly the 11" brakes were in light duty 1/2 and 3/4 tons under 7000lbs gvw..the 11-5/32" ones were found often in vans and 1/2 ton heavy duty trucks with 10 bolt axles mostly..:crazy:
  16. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    My V2500 Suburban, is also with 8600 lbs GVW (3901 kg)
    What is a Gov-loc?
  17. dyeager535
    26,981
    The label in the glove box will show a code "G80".
    It's a factory "automatic locker" with not too good of a reputation. When it works, and is used in mild applications, there is nothing made (so far) that compares to it.
    But they tend to break (quite often comparatively) although the problems are typically in the 8.5" rearends, the gov-lock in my 9.5" was broken when I got it.
  18. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Also known as "Gov-Bomb" due to their nature of failure.
  19. Slapperbar
    Nov 29, 2005
    2,747
    3
    Honestly if it's not a G80 diff, get a Detroit Truetrac diff. For all 'round great manners and performance IMO.
  20. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    I did't open yet, so I don't know if is broken or not. But, I see an oil leak, from the rear end and the oil is red, like ATF!!! Can be ATF, in the axles?
