Rear Bulb Problem
Discussion in 'The Garage' started by daleearnhardt01, Aug 24, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Noticed today that the left side brake light is dimmer than the right and with headlights on and right side signal on the bulb goes out. Any ideas?
  2. diesel4me
    Jul 24, 2003
    17,542
    936
    Massachussetts
    If its a later model(88 up)it might be the printed curcuit board thats built into the rear tailight assembly,they rot out and cause all kinds of goofy problems. If it an older rig,it could be bad grounds,sockets,even the bulbs can have a filament break and touch the other filament and cause feedback problems.You cant really diagnose this kind of problem without being there,but theese are a few things to check out. /forums/images/graemlins/crazy.gif
  3. stevew90
    stevew90 Newbie
    May 9, 2005
    MA
    Tailight problem
    I am having the exact problem with the right rear tailight on my 90 blazer.
    The blinker works OK until I turn on the headlights, then the reverse lights on both sides come on dim. What was the fix on your truck?
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    The socket was bad if I remember...
