rear cab mount bolt broken off, how would you fix ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Jul 1, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    rear cab mount bolt broken off inside the threaded hole in cab, very corrded stuck threads, how would you fix this ?
  2. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I'm dealing with a similar problem; my cab mount nuts are stripped. I did a post on this but have yet to get any suggestions. I'm thinking about using a hole saw to cut an access hole from inside the cab directly over the location of the nut and replace with a regular nut...
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    About the only choice you have is to cut a hole in the floor. I had to do that in 4 places when I put the body lift on mine.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    common problem
    drill beside the origonal hole and re weld the nut to the pan if you can
    hope you have a mig close by
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Cut a cross shaped hole and you can fold the metal back down and re-weld it shut.
  6. dyeager535
    26,978
    Only suggestions I know of (for GM car) is to approximate the location inside the cab, then cut 3 sides of a square around it, and fold it back. At least that way you can weld the piece back easier than what you end up with using a holesaw.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cool thanks y'all /forums/images/graemlins/laugh.gif
    well sounds like the votes going for cutting access spot above there and fixing it that way
    i was wondering about drilling and tapping new threads ?
    but if all it is is a welded nut then hmmm,,,
    thanks
  8. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    you can try to tap it out. and then re-thread the hole
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah thats what id like to do anyways, who knows how it would turn out, always could botl and nut it with large washer or two, hmm
    anyone know what size diamter bolt is and what threads ? 3/8" or 7/16" ? 24 threads per inch
    28 ?
    thanks
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's 1/2-13 I do believe /forums/images/graemlins/smile.gif
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok, cool,
    another Q: anyone ever cut into panel from above and drilled it out ? how much room is there to get drill at the welded nut ? enough ? or ? and about how far in from the inside corner do you need to cut access hole ? ill use a holesaw bit if i can find one quick enough when its time to fix for him, ill get another chevy truck to part out for doing this for him when he brings truck over
    thanks
  12. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    TORCH /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif
