Rear Cap water leaks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89VJimmy, Jun 20, 2003.
  1. 89VJimmy
    89VJimmy Registered Member
    Mar 6, 2001
    12
    Lancaster, PA
    OK, I can't take the water leaking in the back of my '89 any more!!! I bought new seals and my special security torx bit and I'm ready to go. I was just looking for anyone who's done this before that could offer any tips.... i.e. best way to lift cap, use a sealant of any kind on the seals, etc. All advice is welcome. Either post here or e-mail: mbolotine@yahoo.com
    Thanks!!
    -Mike
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Thanks!!
    -Mike
    So this is supposed to be the screw in plug? not the block plugs that you have to press in?
    Either way you need to put some kind of sealant on the plugs.
    On the press in caps I use indian shelak, on the threaded plugs I use teflon tape or type 2b permatex sealant
  3. 89VJimmy
    Mar 6, 2001
    12
    Lancaster, PA
    OK, I can see where I screwed up.... My description is a bit ambiguous. I'm talking about the main body cap, that makes up the entire aft of the truck (from behind the cab to the tailgate).
  4. dyeager535
    26,975
    the topper /forums/images/graemlins/smile.gif
    I'm going to be tackling this job someday soon, and black RTV was suggested as being a good adhesive for the seals.
    I noticed on at least the older ones, a thin strip of butyl rubber (or something very similar) is used on the bed rails just aft of the B pillar, apparently to make sure any water that gets between the two cab to topper seals doesn't run down the sides and into the bed.
    I've also seen Vaseline mentioned as a good preventive measure on the seals when you reinstall them, so they don't get stuck to the bed rails, etc., but it doesn't seem thick enough to last to me.
    Edit: Looking for another post, found this one. Vaseline is not the right choice. GM recommends, and I use, dielectric grease. Obviously when exposed to weather for long periods it wears off and/or picks up dust and what not, but where not exposed it keeps the seals from sticking long-term. Also supposed to help with their longevity.
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    /forums/images/graemlins/ignore.gif
    Like Dorian said /forums/images/graemlins/thumb.gif
  6. Drewminator
    Drewminator Registered Member
    Jun 23, 2003
    14
    Grand Rapids, MI
    I used a foam tape that I purchased from a truck cap dealer. It's about 2" wide and maybe 3/16" thick with adhesive on one side. I stuck it to the topper anywhere it contacts the truck. No more leaks. When you take off the topper it stays with it. It's faom in the middle with adhesive on one side and a plastic coating on the other so it does not stick to the truck. It comes in rolls.
