rear cv driveshaft
Discussion in 'The Garage' started by lunchbox, Apr 19, 2007.
  1. lunchbox
    lunchbox 1/2 ton status
    Jan 22, 2006
    309
    novato,california
    ok, i was was getting real bad driveshaft vibrations so i shimmed the rear end 8 degrees im still getting bad vibrations when i decelerate. is it possible to have a rear cv drive shaft made that would work with my 208? or are their strength problems? i searched it and im still not sure.:dunno: oh and i dont wana drop the t-case.
  2. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    Call High Angle Driveline, they have a slip yoke CV
  4. lunchbox
    Jan 22, 2006
    309
    novato,california
    sick! now this would fix the vibes right? the pinion and d-shaft are strait im gettin vibes from the dshaft to t-case
  5. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    the key on a non CV shaft is to have both U-joints operating at the same angle. If you go CV you will need to rotate rear end so that the driveshaft is in a straight line to the pinion
  6. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
  7. lunchbox
    Jan 22, 2006
    309
    novato,california
    i put the 8 degree shims in so the driveshaft and the pinion are allighned ,(sorry i didnt word it right)
  8. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    are you running a CV now then?
  9. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    This is one of the reasons you are getting vibes; both u-joints need to be at the same angle.
  10. guz71
    guz71 1/2 ton status
    Sep 17, 2006
    387
    lubbock/houston
    If you have a NON cv shaft, then that is why you have vibes. On a non cv shaft, both of the u joints have to be operating at the same angle. With a cv shaft then your pinion has to be pointed straight a the t-case. If you have a lift you may need a cv shaft though. since it gets noticeably worse when you slow down, it sounds like you have some axle wrap too.
  11. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    If no CV needs to look like this:
    If CV needs to look like this:
  12. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i just did this tuesday. cleared right up, now i just have all the other noises and vibes to pinpoint! theres no driveline vibes at all anymore. mine were really bad. i got one used and had to retube it and a new weld yoke on the end, iverall it cost me $260. new they wanted $500:eek1:
    heres a good read:
    http://coloradok5.com/forums/showthread.php?t=202539
  13. lunchbox
    Jan 22, 2006
    309
    novato,california
    im at school right now so ill take pics and post them up when i get home, for some reason i think ive screwed up my description, so i think pictures will help, sorry
  14. lunchbox
    Jan 22, 2006
    309
    novato,california
    the pinion u joint is good its the t-case
  15. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    I think we understand your description perfectly fine; Both angles are wrong.
    To run u-joints at each end of a shaft they have to turn through the same angle. This means you need to lower your t-case and/or rotate your pinion down (smaller pinion angle shim) to match the t-case joint angle. You can't run one joint at 0-deg (your pinion) and one at some other angle w/o vibration.
    Your pinion angle is set up rigtht now the way it should be for a CV shaft.
    Check out the picture below:
    Notoce how the angles at each joint are the same? If the working angle are both the same, but exceed more than about 5-deg, you will also get vibration. If this is the case then it's time to consider a CV shaft. I would first try and match you pinion and t-case angles before spending money on the CV setup.
    ______
  16. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    x2 what Loafer said.
