Rear CV driveshafts??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Nov 15, 2001.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Was contemplating cutting my perches off and rewelding then in the proper angle position, but that seems kinda final when I am not too sure about what my future plans hold for this truck. I dont want to be cutting them off, again and again to fix my angles everytime.
    So, who is running a CV rear shaft?
    Did you just cannibalize the CV joint from a front shaft and weld it to a rear shaft? Or are they custom built from scratch?
    I figure that this will be the best thing and will let me do basically anything to the rear diff and it should pretty much compensate...
    Any inputs?
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  2. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I am running a custom built CV rear drive shaft on my NP205. It uses a Ford Bronco NP205 1330 CV style output yoke on the 205 to accept the 1330 CV drive shaft end. Hope this helps.
    I may be slow, but I sure am fat!
  3. CarolinaBogger
    CarolinaBogger Registered Member
    Apr 17, 2000
    86
    Boone, NC
    I got a complete rear CV shaft from Arizona Drivelines for $320. Now, anyone correct me if im mistaken, but i've heard that you could get a CV out of a Cadilac? or Olds Bravada and weld it into your Blazer shaft if you wanted to do it yourself.
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I guess if you didn't want it balanced or what not you could make one... but considering it is about $50 to have one balanced why mess with it IMO.
    I currently have a slip yoke style CV shaft soon to be a fixed yoke type I hope.
    I would say give Jesse a call at High angle driveline. You'll get like 10% off.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  5. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I have a Caddy CV im mine, it uses a dodge flange yoke on the t-case, and the CV which uses that GM joint, its not a spicer size, but is comparable to a 1330 i think, it works well and i have had few problems with it, however, as i told someone else, if i had it to do over again i'd go with the spicer style 1350 CV. As was said give Jesse a call, he'll steer you down the right track.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Get with JEsse at Highangle Driveline.
    www.nashvillek5.freeservers.com
  7. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Hey Raised, is that the CV with a pivot in the middle of it? Do know what it's "officially" called? See my CV Joint post.
    Real trucks don't have spark plugs!
  8. Thumper
    1,582
    Alberta Canada
    ok, thanks for the input... but I am unfamiliar with the 1330/ 1350 numbers of u-joints...
    Are these part numbers? The ones I buy are from Napa (Canada) and they are number PUJ 369. Does that equate to anything you guys are talkin about?? The same ones I use are number V153 from Bumper to Bumper. They fit into my stock 79 NP205 and the 74 12 bolt yoke if that helps.
    Mike
    85 Fullsize Jimmy
  9. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    1330 adn 1350 are the series , 1310 is half ton 1330 is 3/4 and 1350 is 1 ton kinda
    dents ....
    O R D's axles
    NO BREAKAGE :)
