rear cv shaft vibration
Discussion in 'The Garage' started by MJB774X, Mar 22, 2004.
  1. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    at about 50mph I get a vibration I think its the driveshaft, I have a 1350 cv rear shaft, the pinion does not point straight at it so I think thats the problem, how do I figure out what degree shim to install, I also have a zero rate block, I know you can buy them that are already tapered, does anyone have this set up so I can just get the same block instead of guessing?
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    ummm...if you will not be needing those zero rates... /forums/images/graemlins/whistling.gif i sure could use those. Sell?
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I was told you use an angle finder to check that. Diveshaft guy say you must shim it to within 3 degrees of the driveshaft. If it is slightly down it is better , remember axles moves pinion up on accelleration. Your profile says 6 inch lift. Is it springs and blocks with zero rate or something else. My four inch shackle flip put my 12 bolt perfect. When it is shimmed proper after finding angle it should look like this:
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The pinion angle doesnt have to point straight at the t-case. The two angles where the ds goes to the t-case and where the ds goes to the rearend have to be within 2* of each other. I had to drop my t-case 2 inches and use 2* shims.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Just going off what I was told by driveshaft guy and pictures at Tom Woods site. I have no problems with mine, even on freeway. /forums/images/graemlins/thumb.gif
