rear d44 gears fit front?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, Oct 25, 2000.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    will gears and carrier from a rear dana 44 fit into my frony 44 without a hitch? i do have to change the side gears though(theyre 19 spline)
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    All front 44's that came factory from GM are standard rotation. As long a you use a standard rotation rear(which most are) then they will work.
    I am not sure about the spider gears though.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The axles should be 30-spline at the carrier for any Dana 44 front found in a fullsize GM trucks. Some older 44's found in Jeeps and such had a smaller spline count.
  4. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    Brian I promise that they will fit. I would not have gave them to you if they would not work. ok. Just make sure you
    know what your doing when you install them. Brian
    "IF YOU'VE NEVER BEEN STUCK.....YOU'VE NEVER BEEN WHEELIN"!!!
