Rear D60 info
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4Freak, Jul 20, 2002.
  1. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I'm looking into buying a D60 to put under the back of my 79 K10. I realize that there were different versions of this axle and was wondering if there are any I should stay away from or look for. Thanks for any help.
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Re: RR D60 info
    I'd stay away from a D61, this is a variation of the D60. The D61 housing is designed for the very high ratios, such as 3.07, 3.23, etc. (the pinion is offset to allow for the large pinion on the high ratios). I know this housing is limited to a 4.10 Spicer gear but I don't know if any aftermarket companies make lower gears for it.
  3. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    Re: RR D60 info
    Thanks for the info. Any idea what these came in?
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Re: RR D60 info
    These are most common in Ford vans. There easy to catch though, the diff webbing has "61" cast into it so if you see one - RUN! /forums/images/icons/grin.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: RR D60 info
    a RR60 for the rear is a custom built axle using a rare ford front 60 housing or an $$$ aftermarket housing.
    I doubt you will have to worry about a RR61.
    IIRC ford didnt use carrier splits so any one will work.
    this is usually a Heep mod and I dont see the point in a fullsize.
  6. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Re: RR D60 info
    By RR60 are you referring to a regular rear Dana 60 FF axle? Rear Dana 60 FF's are pretty common in non-GM brand vehicles. Am I having a thick headed moment?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: RR D60 info
    Why not use a 14 bolt FF? It will go in so much easier and its stronger anyway. The only advantage of the Dana would be that you can get lower gears for it.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: RR D60 info
    RR usually means Reverse Rotation
  9. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    RR=rear Sorry for the confusion. I mainly wanna go with a D60 for weight purposes and the larger selection of lockers. It will be plenty strong for my use. I'm not totally stuck on the idea of a D60 but right now it's what I'm thinking about, I may end up using a 14 blt anyway. Thanks.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the 60 is a nice axle but has smaller shafts then a 14 or 70 and has many variations.
    you would have to do your homework and pull a shaft on a prospective dif to know what you are getting inside
