Rear deferential
Discussion in 'The Garage' started by 84mudmachine, Apr 4, 2005.
  1. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    I'm going to replace the rear pinion seal and change the diferential fluid as well. I have a 10 bolt, what is the size of the pinion nut and what oil to you recomend using. I have a leak on the output shaft on the transfer case also, would this be a good time to do that, and what does it take to do it.
  2. 84mudmachine
    Dec 23, 2003
    184
    Kansas
