Rear defroster on 86 K5 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlkBlazer86, May 17, 2000.
  1. BlkBlazer86
    BlkBlazer86 Registered Member
    May 16, 2000
    15
    Plainfield, IL
    I just recently bought a 86 K5 Blazer and it has no rear defroster on it and I wanted to add one. My first question is that a difficult job to do? Can I go to the boneyard to get the parts from a late model Chevy?
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Someone mentioned a long time ago something about installing the ones from a burb. It sounded like two blowers on each side blowing towards the rear window. Perhaps he/she will post again please?
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  3. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    I do not think this was ever an option. I have seen doncos that have it, so it seems like it should be possible. You might check with a glass shop, they could tell you if it is possible and pricing. The other options were all w/ blowers or heaters.
  4. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    I would imagine that wagoneers are a possibility too. I had an 85'.....The fullsize kind...not cherokee. their back glass iS Around that same size as a blazer. Also it's not the blowers like a 'burban. wagoneers have the defroster lines that run across the glass....i think you should be able to buy new defroster lines too....i really don't know how hard it would be to remove existing lines from a window.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  5. BlkBlazer86
    May 16, 2000
    15
    Plainfield, IL
    Thanks Michigan I am going to look into that...
    Always Chevy Powered!!!!!!
    BlkBlazer86
  6. BlkBlazer86
    May 16, 2000
    15
    Plainfield, IL
    Thanks Blazer I will look for that to post again.
    BlkBlazer86
  7. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    According to the 87 Dealer Brochure found on http://www.slosh.com/cars/brochures/blazer4.html this was an option. You should be able to order the window through the dealer or maybe a glass shop and install a hi amp toggle switch yourself. I attached the picture.
    Shawn
    87 K5
  8. BlkBlazer86
    May 16, 2000
    15
    Plainfield, IL
    Thanks Shawn this really helps I have a call out to the dealer for the window...I will post all of the particulars in case someone else has the same problem...
    BlkBlazer86
  9. Shawn
    1,753
    5
    5280'
    No problem. I always wonder why you never see this option on any K5 Blazers. You will see it on a Suburban but never on a Blazer. Anyone have this option on their Blazer?
    Shawn
    87 K5
  10. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    I work at a glass company and have never seen a defroster on a K5. I will check and see if one is available this week and get back to you. I think it would be too much of a pain in the a@@ to do. If the lines get too much juice the window will blow.
    <font color=blue>Blazerbob</font color=blue>[​IMG]
