rear diff. drain plug, damn thing stuck
Discussion in 'The Garage' started by XHitman396, May 6, 2003.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i was gonna check the oil level in the rear diff cuz of wierd metal on metal sound back there, so i try it with the breaker bar and wouldnt budge and stripped it out, today took it to texaco lube express, they had a special piece thingy to fit it, and it took a 230lb feller and about 3ft worth of leverage, and still didnt budge, so they stripped the [censored] out of it, and said its been there so long and heat so intense its practically welded in there. then the local 4x4 shop tells me that i gotta have a machine shop do it, im assuming the will drill it out and rethread and put a new one in? any other ideas, is this expensive, only way to go, any help?? thanks... btw, i read a post a couple days ago about the most stubborn bolts or whatever on your truck, and so far, this is the blue ribbon.....
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Drill it out to a good size... maybe 3/8" or 1/2" or so and get a big easy-out. The extra heat from the drilling might do it some good.
    If it still won't go, drill it out until its basically gone and re-tap it.
    Theses tools might cost you as much as having it done, but then you'll have the experience and some tools for another project.
  3. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I would assume that is what the machine shop would do. Just curious, what 4x4 shop did you go to?
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Is this in the inspection cover, or the housing?
  5. Looksback
    Looksback 1/2 ton status
    Aug 12, 2002
    120
    Montana
    I had that same problem about 3 years ago, Thats what I had to do was take it to a machine shop thay removed the plug, did not find out how but thay did. Here is a real good note when putting one back in, gett one that has a square top to it that sticks out, that way the next time you can just put a wrench on it and remove it. Did not cost alot to have them remove it at the machine shop about $15, and that was including the new square top plug, but it did take them along time, about 3 hours.
    LooksBack
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    What if you heated it up around the plug? Like you would do on say, oil galley plugs.
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    That would work.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    or...take off the diff vent fitting and check the oil level from there, just measure the distance from it to the fill plug. you can also fitt it through the vent...been there, done that
  9. XHitman396
    May 3, 2002
    620
    the shop was Young Four Wheel Drive, used em before, i like em, and nice ol boys. how bout this, rather than goin through hell with takin the axle off etc, is there somewhere that they make the diff cover with the plug hole there, rather than on the housing, where can i find one, and could i take the one i have now off and have it drilled and tapped, thanks yall...
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I had to weld a bolt onto mine. Then used a ratchet on the bolt then just cleaned the threads and put a new one in.
  11. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Same thing happened to me, I did what Kevin said and employed the talents of the all-mighty EZ-Out! It took about half an hour and now I'm a rear-diff-maintainin'-mofo! /forums/images/graemlins/grin.gif
  12. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    mine was stuck on my s15 and i stripped it out too.
    so i drilled a hole in it , then used an ez out.
    cleaned up the inside , new plug and gear oil and good to
    go /forums/images/graemlins/thumb.gif
