Rear Diff exploded
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5Blazer, Sep 10, 2002.
  1. 90K5Blazer
    90K5Blazer Registered Member
    Jun 10, 2002
    48
    Dayton, Ohio
    170,000 miles and the rear diff has had it. Not in a mud bog or a rock crawl but doing about 25mph on the street. Sucks! anyhow, does anyone know if I can use a diff out of any K5 with a 10 bolt 8.5"? If not what years will fit? And if the whole diff won't work what about the carrier out of another diff? I plan on doing lockers and regearing, but for now I need a quick fix. and a cheap one too. Any help would be greatly appreciated!! Thanks in advance.
  2. dyeager535
    26,980
    Gotta watch axle spline count. Think the 28 to 30 spline change was '88.
    You could swap carriers, and use the same side gears, but not really that good an idea, or likely possible, if yours grenaded. You could always get another 10 bolt any year, complete, and bolt it in, regardless of spline count.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Any year from an 80 or so pickup or K5 to 91 or 87 for pickups. The 88-98 bodystyle vehicle's axle will not bolt up.
  4. dyeager535
    26,980
    The spline count changed..you can use a *K5 axle assembly from '80-91*, but the spline count did change, which means side gears are different, hence my answer to his question about if the whole thing won't interchange...
    Just find another axle assembly that is from an '81-87 truck (or '91 K5, burban, etc) with the right gear ratio.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    actually, anything from 73-91 should bolt up as long as its not a 1 ton...the earlier ones will be 12 bolts though...maybe its time to upgrade to a 14 bolt?
  6. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    dyeager is right. If you don't buy the entire axle, and just get the differential, you have to watch spine count. I believe he is right, '88 is the break year, with 28 splines before, and 30 after. But if you get an entire axle, no worries about spline count then.
