Rear Diff leaking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAPTAINK5-CT, Jun 19, 2001.
  1. CAPTAINK5-CT
    CAPTAINK5-CT 1/2 ton status
    Sep 10, 2000
    124
    CT, USA
    All of a sudden, out of the blue, my rear diff is dripping. Haven't crawled under yet, any thoughts?
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Pinion Seal ?
    FYI, understand the term "pinion bearing pre-load "
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Captain, have you had your rear end rebuilt recently or something? "Usaually" if you dont have the correct, "Pinion bearing pre-load" your pinion nut can back off a little and cause the pinion to wobble a little bit and thus the pinion seal starts leaking.
    #2. You just could have a bad pinion seal that needs to be replaced, it happens.
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  4. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    Check your vent tube...that is what was causing mine to spring a leak...i fixed it once and then a few days later it started up again...cleaned out the vent tube and problem solved
    Donations accepted for the "Build Chaz's 1972 K5 fund"!!!
  5. CAPTAINK5-CT
    Sep 10, 2000
    124
    CT, USA
    Thanks for the info. I spoke with my mech and he said the same thing, maybe pinion seal. We'll have to check it out.
  6. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    try the gasket to thats what mine was doin changed that gasket and it stoped ...just my few words.
