rear diff locks up .... without a locker
Discussion in 'The Garage' started by thezentree, Nov 16, 2003.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    yea, so i was backing up outta my driveway the other morning, and i noticed the inside rear tire was skippin like it was locked up. put it in drive and it went away. it kinda freaked me out, but it didnt do it again so i figured it was a fluke (thats a bad thing to figure...). well, it did it again several times this morning.
    its a 97 yukon with a 10 bolt and no locker/posi (unless it hasnt worked for the past year and a half and is just now starting to).
    anyone ever had this happen? what is causing this? /forums/images/graemlins/1zhelp.gif kinda unnerving knowing that your diff could grenede at any second /forums/images/graemlins/smirk.gif /forums/images/graemlins/confused.gif
  2. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    : kinda unnerving knowing that your diff could grenede at any second /forums/images/graemlins/smirk.gif /forums/images/graemlins/confused.gif
    Possible that the brake pad is dragging/ jamming?
    Pull the wheel and drum, have a look....
    Rearend??? Don't know-
    I think you need to pull the cover, and look for bad news /forums/images/graemlins/frown.gif
    Would'nt drive it around too much until you look at the gears.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I'd look real close at the spider gears. Brakes are a possibility too, but I'd still look in the diff.
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    It's a free locker, don't bitch!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Just kidding, hope it's nothing serious /forums/images/graemlins/eek.gif!
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Have you owned the truck since it was new? You sure that it doesn't have a Gov-Loc that just has never worked? Either way, sounds like it's going to go kaboom at any time.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have seen alot of problems with the 88-98 era 10 bolt rear 8.5" axles, have seen several break apart, a guy i know locally who has a 95 k1500 pickup has had to buy new gears and everything for his 8.5" twice now
    GM apparently quit making good axle parts back in late 80s or before even, im always going ot try and avoid anything later 80s and up with an 8.5" rear, cant avoid 8.5" up front though but ive enver seen any fornt axles come apart, but not alot of ppl have 4x4's around here though
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    and also...most people rarly ever use 4x4 so the front diff usually dont get much use anyhow /forums/images/graemlins/smirk.gif
  8. thezentree
    Sep 19, 2003
    7,198
    NC
    i didnt think the 10bolts came with gov-lock...
    whats the code for gov-lock on that sticker in the glove box (too tired to remember what the correct term is)?
    its not brakes, because the wheel is spinning faster than it should, as in, its breaking loose and spinning rather than being dragged.
    good lord, it never ends /forums/images/graemlins/smirk.gif
    time for a 14BFF... /forums/images/graemlins/crazy.gif
  9. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    the GM code for a Gov-Loc is G80. /forums/images/graemlins/thumb.gif
    Rick
  10. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    Lots of 10 bolts come with gov-locs, expecially in 4x4s.
  11. thezentree
    Sep 19, 2003
    7,198
    NC
    so, my truck IS gov-lock equipped...
    next question - why is it just now starting to work? i dont know too much about em, are they just a limited slip
  12. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    More likely is that it is just starting to break /forums/images/graemlins/eek.gif Not the news you want to hear, but sounds like a Gov-Lok that is about to bite it. /forums/images/graemlins/crazy.gif
  13. thezentree
    Sep 19, 2003
    7,198
    NC
    awesome! /forums/images/graemlins/frown.gif
    maybe i can get the 'rents to help with that 14BFF conversion...
  14. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    Exactly. Gov-Locs are kinda funny, sometimes you don't even know they're there until they explode and scatter bits all over the place. At this point I'd venture to guess that you have some pretty fancy carnage going on in the bowels of the diff.
    Keep running it for awhile and you might be able to compete with zcarzcar for the worst 10 bolt carnage. Better yet, get your 14 bolt ready to go, then right before the swap take the truck to the end of the driveway, put one tire in dirt and one on asphalt, rev it up to 5 grand and drop the clutch or do a neutral drop on it. That should make for some real interesting fun. /forums/images/graemlins/thumb.gif
