rear diff problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Nov 16, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I opened up my rear diff last weekend and I found that I had
    a limited slip. It had springs and clutchs is this the infamous gov-lock? I have no clue what they look like so can somebody help me out on this?
    My problem is when turning my drivers side rear sounds like the brakes are binding up with my foot off the brakes,
    when I am going straight it does not make a sound when I slow down (almost stopped) it starts to make the sound again but not to intense until I turn. no sounds that i can tell are coming from the passenger side. When I Put fluid back in it I did not have any additive (finally got it today) Could this be the cause? or could it be that my Drives side tube bearing is bad. the best why that I can describe the sound is a popping with a nice bang shortly after, it does it until I stop or get going straight again, it will also make the sound when I start to back up
    If this does not make any sense at all I will try to explain better this is driving me crazy
    *wink*
    my 79 rust bucket will run over your 2001 chevy 4X4 tahoe plastic wagon
  2. CarolinaBogger
    CarolinaBogger Registered Member
    Apr 17, 2000
    86
    Boone, NC
    I had the same symptoms. The popping sound intensified when i was turning up a step hill or driveway while on the gas. It turned out that I blew an axle bearing and also toasted an axle. Pull your axles and inspect them. Also, check the spyder gears in the diff.
  3. dyeager535
    26,982
    191
    www.dorianyeager.com/index2.html
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Use the GM posi additive and it will go away provided you have no mechanical damage.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  5. Redfrog
    May 4, 2001
    753
    IL
    Thanks for the break down, now I can figure out what I have
    the problem seems to be in the drivers side brakes (thank god) they are shifting towards the back Why I don't know yet
    but I will figure it out so Thanks again
    *wink*
