Rear Diff. Yoke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MyK-5, Jun 23, 2000.
  1. MyK-5
    MyK-5 Registered Member
    Jun 18, 2000
    50
    Phoenix
    I recently bought a 81 K-5. Someone put a suspension lift on it and i dont think they did it right. When i am 4 wheeling and am crawling over stuff the rear yoke and the drive shaft pinch the u-joint. is there a cheap and easy fix for it?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    how is the rear lifted. springs or blocks? I have used axel shims to correct pinion angles but don't like to use shims and blocks together. but I guess it can be done.
    your right. I don't understand the jeep thing!
  3. MyK-5
    Jun 18, 2000
    50
    Phoenix
    its lifted by springs. someone told me to tilt the axel to a different angle. but i am not sure. i am wondering if i put new shocks on it if it would make a difference.
  4. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    <font color=purple>Nope shocks won't fix it. But a 4" lift with springs really shouldn't be causing this problem. Tilting the axle would help. However that can be expensive. Take a good look at your driveshaft, is it bent, maybe they lenghtened it to much? just some things to ponder.</font color=purple>
    <font color=purple>Rick
    86 K-5</font color=purple>
    http://www.BigBadBowTie.ColoradoK5.com
