Rear diffs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kustom71, Jun 26, 2004.
  1. kustom71
    kustom71 1/2 ton status
    Mar 14, 2003
    117
    NJ
    Arent rears from an 86 k5 blazer and a 77 k10 pickup the same(interchangable)Also if the front and rear gear ratio is different will it hurt anything?????? /forums/images/graemlins/crazy.gif
  2. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    as far as bolt in yes they are the same but the gear ratios beign different can you say brokin thats no good
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    If the front and rear gear ratios dont match, and you put it in 4wd, it WILL cause something to break!!
    -Harrison
  4. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I forgot what the "maximum percent difference" you can have between front and rear gears, but if you have something like 4.10 and 4.11, you're OK. I remember the old 70s Ford F250 had 4.10 in the rear and 4.09 in the front. You run into trouble when you start matching 3.73 with 4.10 or 4.10 with 4.56. Also, your front and rear tires have to match in height as well. Not just the height stamped on the sidewall - if you are running different tires front and rear, you need to get the manufacturers spec. sheet on the tires and make sure the actual heights match front to rear.
    Good Luck,
    Eric M.
