rear disc ?? ASAP
Discussion in 'The Garage' started by Jason4x4, Mar 31, 2007.
  1. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I am doing the 14ff disc swap right now. I want to put the rotors on the hub, and the head of the stud is bigger than the indentation on the disc. Do I need to grind all the stud heads down to fit, or are you guys running them like that? they are the napa premium rotors. thanks. I can get pics if needed.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    just press them in and go
    mine have been that was for 3 years now, no problems
  3. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Mine had the same problem, once I pressed them in as far as I could, I found that they were to short also. I ended up getting the correct sized ones in the end.
    If yours are long enough, I would not worry about to much. I am pretty anal about how things fit, thats just me though.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    mine were not to short
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I had to well 4X4HIGH had to turn each bolt on a lathe in order for mine to work.
  6. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    As I remember it was due the difference in studs for the rear verses the studs for the front. Since the disc's that we use for the conversion are really for the front it all makes sense.
