Rear disc conversion
Discussion in 'The Garage' started by 69K5, Nov 30, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I am going to get my birthday present tommorow (14ff). I was wondering if anyone had made a homemade rear disc bracket. I looked around and it all looks easy. I found 3 and I just cant find any specs on the backing plate to hold the caliper. I wanted to just buy a set but with tuition due it will be next summer before i have 100.00 to send to a-tron anybody have any ideas or specks?
    thanks
    69K5
    nathan
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
  3. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Just get some caliper brakets from a 10 bolt front axle, Hog out the center so it fits over the housing. Mock it all up with NEW pads and tack it to the housing with the calipers in place. Remove the calipers and weld it on. Get rotors from a 3/4 ton ford (78 i think is what i used) they are half the price of the chevy ones.
    Brian
    82 "Burban-Like" vehicle
    D60/14FF sm465/np205 40" TSL
    with a 84 K5 removable top
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Jeffro
    thanks for the idea. /forums/images/graemlins/thumb.gif
    Burbboy
    Do you have any pics ? Do the ford and chevy rotors have the same bolt pattern. /forums/images/graemlins/confused.gif i thought that chevy wouldnt go w/ ford bolt patterns? /forums/images/graemlins/thumb.gif
    thanks
    nathan /forums/images/graemlins/grin.gif
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    All 8-lug (untill furd screwed it up with the superduty) are on a 6.5" bolt circle. My 3/4 ton chevy rotors were $35 each from autozone.
  6. burbBoy
    Feb 4, 2002
    358
    WI
    I guess it depends on your location as to the price in rotors. I shopped around here and for the chevy rotors it was around $50-$60 each and the ford ones were around $30 or so. As soon as my scanner is working i will post some pics of my set-up.
    Brian
    /forums/images/graemlins/burb.gif
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    burb boy
    cool thanks. i will shop around and see which is cheaper here in LA. Probably chevy b/c they pretty well rule the south.
    thanks
    nathan
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    triaged
    I need some technical advice again. what is required to change the 14ff to make it easier to do the disc brakes on the 85 and newer. i dont know if the 2 i looked at are that old or not. he just had them sitting on the rack, so i will have to go back and check. What im trying to figure out is it worth swapping or just look for another axel?
    as much as you help me out i owe you like 100 favors already. if you need something let me know.
    thanks
    nathan
  9. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I've actually never seen the 85 and up axles...and there are like 10 guys in our club with 14FF's. I think I would jsut stick with the older ones if you want to go disc brakes.
  10. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
  11. Robbie6987
    Robbie6987 1/2 ton status
    Jul 16, 2002
    111
    killeen TX
    I dont know the exact years, but look at the drums on the 14blt if u can slide them off like a 10 or 12blt, the disc brake rotors wont fit the hubs.
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ok thanks
    nathan
  13. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i went and checked the axel. i dont know what year it is but its the right kind for the breaks.
    nathan
