Rear disc fitting sizes needed.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by marine_enlisted, May 5, 2004.
  1. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    I am trying to order fittings for my rear disc swap. I am running late 70's Chevy 3/4 front calipers. I have ordered a stainless hose kit for the front and rear hoses and want to run some AN-3 stainless hoses from the rear calipers to the hard line on each side. I would like to run a banjo fitting on the caliper to a 10" 3-AN Stainless hose with a 90 degree fitting on the caliper end and a straight fitting on the hard line end. What size banjo bolt and fitting do I need to order?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If its a D44 caliper is 7/16 banjo, D60 and 10bolts are 10MM IIRC
  3. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
    Would it be 7/16-24 or 7/16-20 UNF? What is UNF?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    7/16 - 24
    UNF is Unified National Fine thread
  5. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
    Cool, Thanks.
