?Rear disc on 14ff?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Shralper, Oct 9, 2001.
  1. Shralper
    Shralper Registered Member
    Sep 19, 2001
    13
    Sunriver, OR
    Ok I need some edumacation here on this rear disc conv. So how do the ff axles bolt to rotor assembly? Just like original drums? What about holding rotors on, original lock nuts?I've just picked up a 14b ff. It'll be a couple weeks before more $$ for brake parts. I haven't seen any of the rotor's folks have mentioned in previous posts so just wondering before I buy/install. Lookin at brackets for use w/ 82-84 10b 3/4t rotors. Thanks
  2. lv2whl
    lv2whl 1/2 ton status
    Mar 4, 2001
    130
    CA, USA
    TRY DOIN A SEARCH ON IT, YOULL FIND SOME GOOD INFO
  3. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    The rotors ride on bearings on the spindle just like the front end.
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    The rotors are going to take the place of the drums. You drive the lug studs out and swap over. The studs hold them in place. The axle shaft bolts up to the original bearing hub. Simple deal. I'm using the rotors that came with my TSM kit, but the front rotorss will work. I'm also using calipers just like the ones on the front. Makes it easier to buy parts and was a helluva lot cheaper. The brackets will bolt on where the original backing plate was. This was about the easiest mod I've ever done. Nothing too it at all.
    Kyle
    89K5
  5. Shralper
    Sep 19, 2001
    13
    Sunriver, OR
    Ok,cool. Now what if I dont have the original drums? Lugs, no problem. But what about bearing hub? Parts store or dealer or? Thanks again
  6. Kyle89K5
    2,273
    OKLAHOMA
    The parts house has got them, but they might be kind pricey, same with a dealer. Best bet would be another salvage. Do you have basically just a housing and shafts or ???
    You'll want to use new studs when you put it all back together, they will run about $1.50 apeice, the bearings and seals on these things are cake to change, so pick them up, and don't forget, their is a little metal ring that goes between the axle flange and the hub, I didn't think it was a real big deal, it was, mine leaked [​IMG] I think the ring ran me about $3 for a fel-pro.
    Kyle
    89K5
  7. Shralper
    Sep 19, 2001
    13
    Sunriver, OR
    Hey thanks!!I finally fingered it all out. My problem was I got the 14b but didnt take the drums when I bought it. Found some nearly new rr brake hubs $50 at junkyard. Got everything else so I'm set. Thanks again
  8. OneLeft
    OneLeft 1/2 ton status
    Aug 14, 2001
    111
    Colorado USA
    i dont know if it helps any, but there are pics of my 14ff w/disks on my members ride page.....see link below
    <font color=red>One</font color=red><font color=blue>Left</font color=blue>
    Have <font color=red>K5</font color=red>, will travel.
    <a target="_blank" href=http://coloradok5.com/gallery/OneLeft>See my ride</a>
