rear disc problem...
Discussion in 'The Garage' started by shaun89, Mar 31, 2007.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i just put on my diy4x rear brakes and used just normal napa calipers (not the caddi calipers) and 3/4 rotors, one side is fine but the passenger side is rubbing A LOT, my truck feels like a bad alignment from it and i cant seem to fix it, the bottom bolt and slider on the caliper are normal but the top slider is all the way pushed out and the caliper is up against the bracket and has no play. im scared to get the hammer out before asking for some advice, maybe someone could help?:confused:
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I know all the brake brackets are test fitted with calipers before they leave the shop, so if you could snap a pic it could be very helpful.
    Thanks,
    Brett
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Yep, we fit them all these days. We do however keep them as tight as possible with our caliper which was selected for its small size. If you need to grind a smidge on the inside of the bracket ear it won't hurt nothing. Caliper castings can vary a great deal from one to the next. I'd rather start small than too big.
  4. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    hmm ok,i think ill try and grind down a tiny bit to make it float better, thanks kert!
